Whowe3rd's avatar
Whowe3rd
Novice
Jul 21, 2014
Password issues
I have a WN3000RP extender that I just factory reset and reinstalled...it sees the network and sends out a network_ext signal but it won't accept the password which I have verified....
1 Reply
  • Is it something was working before with same device you had ?
    It is pc you are trying to connect?
    Did you try deleting the wireless profile first and try again if this was pc. ?
