Genny28's avatar
Genny28
Problemi con extender
Salve sto riscontrando problemi di segnale del extender con il router. Ci tengo a precisare che dall'acquisto del prodotto fino a due giorni fa tutto funzionava senza alcun intoppo.
Come posso risolvere?Grazie in anticipo.
  • plemans's avatar
    What problems are you having?
    What firmware is on the extender?
    What router is it connected to?
    What method of setup did you use? WPS or the installation assistant
    • Genny28's avatar
      Genny28
      The model is a AC750 WiFi Range Extender(EX3700).I do not know the firmware but for a few days the signal with the router is poor. (the connection is bad both in wps and through assisted installation).
      How can i solve?
      • plemans's avatar
        What router are you connected to?
        what size is your home?
        what material are the interior walls of your home?
        Is there a lot of people living around you? Maybe there's interference.
        Have you tried changing wifi channels?
