Flavia
Dec 04, 2015Follower
Problems connecting EX2700
Hello
I have a netgear extender ex2700, it was running perfeclty.
However, yesterday I couldnt't connect in the EXT wifi anymore.
My EXT wifi appears normally, but I cannot connect to it.
When I have my extender on the outlet, the Router light is on and stable, however the device light is off all the time, but if I try to connect to the ext wifi, the device light turns to green and stable.
I tried to reset, in order to start a new setup, however my ext wifi continues active.
How can I solve this problem.
I'm sorry about my bad english, I'm using it in Brazil.
1 Reply
- nhannNETGEAR Employee Retired
Hi Flavia,Please try changing WiFi channel on your Router
You can reset your EX2700 to factory defaults by following page 34 of 43:
http://www.downloads.netgear.com/files/GDC/EX2700/EX2700_UM_19Oct2015.pdf
Then place your extender in the same room as your router and complete the Extender setup process.
Also check that you are running the latest firmware v1.0.1.8
