bikerant
Apr 28, 2020Aspirant
Problems connecting to NETGEAR Wi-Fi Range Extender EX2700
Hi,
I've been able to pair the extender with my PlusNet router no problem (using WPS button); however, I'm unable to connect to the extender...tried several phones and an iPad...could see the extender but when connecting, kept saying the p/w (same as router) was incorrect...
Can anyone advise on a solution beforer I return the item?
TiA, Tony
Oh my days...I've done it..! ...Using the ethernet cable from the PC to the extender and connected the PC to the router via wi-fi... I wish I'd known that before as it was pretty straightforward via that route. Phew!
Thanks for your help!
Tony
try factory resetting the extender and re-running the setup using the installation wizard.
Wps doesn't always work well between different manufacturer's which is where there's the installation assistant.
- bikerantAspirant
Hi, thanks for suggestion but can't get this to work...
Just to clarify...
- extender sees my router and creates a netwk with _ext at the end
- My iPhone (tried a 5 and a 6s) sees the netwk in settings/Wi-Fi
- I try to connect to to it using the same p/w as my router
- it rejects the password
- I go to the my wifi ext URL (this post won't let me type the full address) from a browser (as recommended) on my phone but my model is not listed
- So I can't run the installation wizard
- If i try to tap the suggested iOS URL on the above page, I just get a blank page
What am I doing wrong, please?
TiA
Tony
worst case scenario?
factory reset the extender, hardwire into it via a laptop/pc for setup.
It tends to go smoother.
