Sheepish95
Mar 15, 2020Aspirant
Problems X6s wifi extender connection
Hello, I have recently set up the X6S extender to my nighthawk router following netgears youtube video and it says it's all connected. Alot of the time I move around now I'm getting connection problem...
Mar 16, 2020Guru - Experienced User
What router is the EX8000 connected to?
How big is your home?
what are your interior walls made of?
How far from the router is the extender?
How do you have the extender setup? ap mode, extender mode, etc
what channel did you using to setup the backhaul
- Sheepish95Mar 16, 2020Aspirant
X6 R8000
Not huge small 4 bed
Brick some steel RSJ's
20meters ish
No idea just set it up using the WPS button
(Not very technical minded) :)
- plemansMar 16, 2020Guru - Experienced User
Sheepish95 wrote:X6 R8000
Brick some steel RSJ's ------Brick and steel are the greatest/best blockers of wifi. :(
20meters ish
If you have brick and steel interior walls, thats going to be an issue for you. They both are the 2 best blockers of wifi signals. You might want to check into powerline, moca adapters, or runner ethernet lines.
