Sheepish95
Mar 15, 2020Aspirant
Problems X6s wifi extender connection
Hello, I have recently set up the X6S extender to my nighthawk router following netgears youtube video and it says it's all connected. Alot of the time I move around now I'm getting connection problem...
Sheepish95
Mar 16, 2020Aspirant
X6 R8000
Not huge small 4 bed
Brick some steel RSJ's
20meters ish
No idea just set it up using the WPS button
(Not very technical minded) :)
Mar 16, 2020Guru - Experienced User
Sheepish95 wrote:X6 R8000
Brick some steel RSJ's ------Brick and steel are the greatest/best blockers of wifi. :(
20meters ish
If you have brick and steel interior walls, thats going to be an issue for you. They both are the 2 best blockers of wifi signals. You might want to check into powerline, moca adapters, or runner ethernet lines.
