Acedoug
Mar 20, 2020Aspirant
Query powerline wifi in multiple rooms
Hi,
I need to put in wifi in multple rooms the walls are to thick to cable inan old house I need to know what powerline equipment would be suitable please.
Regards
Acedoug
you could try powerline, you could try moca adapters, you could even try a mesh setup if you were so inclined. I can't tell you 100% what will work the best because i'm not there.
Acedoug wrote:Hi,
Regards
Acedoug
its tough to say off that. some homes run great with powereline. others have issues due to interference/old wiring/etc.
you might just want to buy a cheap set to test out to see if its even feasible/how it performs in your home.
- AcedougAspirantHi
Thanks for reply. I believe the place was rewired a couple of years ago. So having discussed with the owner they need something in as soon as possible. What would I need to do four rooms wirelessly? One room has a router (zyxel)
Regards
Acedoug- plemansGuru - Experienced User
