MatthewKovich
Dec 15, 2019Initiate
R7000 + EX7000 still not enough
Hi all! I have a modestly sized two-floor bungalow in the Chicago suburbs, and I'm still having trouble getting strong coverage in all rooms. I have the R7000 (AC1900) router and the EX7000 (AC1900...
Dec 16, 2019Guru - Experienced User
How large is this "modest" bungalow? many have differing opinions of what modest is.
What interior materials is this bungalow? many materials do great job of blocking signals. Like if its a concrete floor, its going to block a lot of signal.
One thing I'd look at first is placement. Simple things like hvac within walls/floors/ceilings block signals well. Or if its a metal cabinet you have it resting on. its going to block signals quite well. Sometimes simple things like moving the router to a slighly different location as well as moving the extender, can help quite significantly. i had an issue once where a router was backed up against hvac within a wall and it blocked half the house from getting signal. A simple move a few feet corrected the problem.
MatthewKovich
Dec 17, 2019Initiate
1,600 soft. It's probably building materials, I'll try some new positions.
- plemansDec 17, 2019Guru - Experienced User
If you're able to centrally locate the R7000, it should be enough to cover the bungelow. If you have dead spots from the prior mentioned building materials, setup the EX7000 so it's coming from a different angle and you'll cut those dead spots down to pretty much gone
