archer12
Jan 06, 2019Aspirant
Range Ext wont work with Apple devices
I have wifi router (ATT Uverse) thats feeds EX7000 range extender. Any Apple products hooked to the extender do not connec to internet. They do connect to the extender, but there is no network connection to internet. Mircosoft computers work just fine with either network, but the range extender will not let Apple products connect to internet. I've reset everything numerous times, reset factory default and programmed again, etc, all with no improvement.
Reads like you have already installed the current EX7000 firmware (1.0.1.78) which is known to cause this (and some more) issues.
Head to https://www.netgear.com/support/product/EX7000.aspx#download , select "Previous versions", download 1.0.0.66, unpack the ZIP archive. The EX7000-V1.0.0.66_1.0.126.chk is the file you want - do not to double click or open, but to upload manually to the extender using it's firmware update function. Once done so, factory reset using the reset button (press about three to five seconds) and release. Then re-configure it from scratch as shown in the Quick Start Guide.
- archer12Aspirant
Thank you!. I did as above and can confirm I am now running the previous firmware V1.0.0.66 as mentioned above. I also turned off the 2G and now only have the 5 G running which changed to port settings from auto to a fixed on the mywifiext setup page. However, I still have the same issue with Apple products not connecting through. I can sometimes get a partial page and then it stops. With a Windows computer or phone there is no issues. But with an Iphone, Ipad or Mac, I get no internet connections.
- Christian_RNETGEAR Employee Retired
- BendeegoGuide
Hi ,I also had the same problem ,I could not connect my IPad to the 2.4 network .
i solved my problem by changing the security settings to Wpa psi tkip Wpa Psk Aes
after changing this my iPad and my smart tv connect ,,,
hope this helps you
Regards
Peter H
