PA51
Apr 29, 2017Tutor
Range extender won't pick up new router
I recently installed an Arris SurfBoard combo cable modem and Wi-Fi router. It has two networks, and my Netgear Range Extender does not recognize the faster or the slower one. How can I correct this?...
- May 01, 2017
To factory reset just hold the reset button for 10+ seconds.
DarrenM
DarrenM
May 01, 2017Sr. NETGEAR Moderator
Hello PA51
Did you factory reset the extender and try setup again? Is the new router using WPA2 security?
DarrenM
PA51
May 01, 2017Tutor
I am unclear on how to return the device to factory settings and am researching that now. Any helpful tips would be appreciated.
