chuck159
Jun 05, 2017Tutor
I called the Netgear chat line because my WN3000RP has one geen light only.
 My WN3000 wifi ext stopped working. It has only the ON light lit. I called the chat line and theysaid a tier 2 technician will call me in a couple minutes. He got into my computer and said he could N...
TomMac
Jun 05, 2017Guru
Never PAY for tech support.... there are a bunch of outside companies making believe they are Netgear...Only use the number in the contact support bubble; https://www.arlo.com/en-us/support/contact.aspx
Do not do a search and then pick a number for help...tech support on the Basic ( free ) level is for 3 months at least.
As to getting help. BTW, you are in the Arlo section , not wifi /router section of forum (home wifi )
- chuck159Jun 05, 2017Tutor
I was in the WIFI section of the COMMUNITY forum and this is where I was placed. I was in the NETGEAR CHAT when I was instructed to receive a phone call.......answer a question...is ARLO part of NETGEAR?
- TomMacJun 05, 2017Guru
Of course it is... Just that SOMETIMES messgs from other sections get cross posted to the wrong area and not sure if you were replying to a previous entry
