Josh_Razor's avatar
Josh_Razor
Follower
Nov 12, 2017
Regarding wifi extender N300 model no: WN3000RP
Hi all ,I recently purchased the WiFi range extender and for my Netgear router Netgear D1500 n300.my extender was initially able to detect the signal of my router however, after a power cut, the extender was not able to pick up my routers signal I tried to resetting the extender and going through the setup again..however on the setup page my extender detects every other WiFi router in my apartment but mine..i tried connecting it via WPS as well but no luck whatsoever. My WiFi router works perfectly and all my other devices can detect it and can connect to it with no issues. Is this a problem with my router or my extender? Thanks in advance
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Make sure when resetting the extender to hold the reset button for 10 + seconds so it forgets all the old settings and they try to connect it again to the router.
    DarrenM
