rj1959's avatar
rj1959
Reinstalling a Nighthawk AC1900 WiFi Range Extender
I moved to a new address and now have new internet service. My range extender was setup under my old wifi network. I now can't connect it to my new network because all of the instructions say to connect to the extender's network and then go online to mywifiext.com. I can't go online while connected to that network because it doesn't exist - except in the router. In other words there is no internet connection associated with that wifi network. Any suggestions on how to change the network on my extender?
  • plemans's avatar
    Push and hold reset for 7-15 seconds while the extender is powered on.
    That'll get you back to defaults so you can go through setup again.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
    • rj1959's avatar
      rj1959
      I tried resetting the router and now I have a network named ASUS. I tried logging into it using "admin" and "password" to no avail. Everything I can find on the support site tells me to go to their link which I can't do.
      • plemans's avatar
        Asus wouldn't show up unless your primary router is asus and you're using WPS.
        It might just be another network showing up.
        Have you tried hardwiring a pc/laptop into the extender and using the installation assistant
