pdxskip
Apr 24, 2015Novice
Repeated Disconnecting & Connecting
Occasionally while I'm using my laptop, I notice that the connection to my EX6100 extender disconnects and then within seconds reconnects. This can happen repeatedly for several minutes. It just happ...
sandand
May 03, 2015Aspirant
This is what the console on my MacBook returns, when it gets disconnected from the extender network. I'm using WN3000RPv2. As you can see, the connection quits at 11:32:45 and then resumes at 11:34:28.
Maybe, is there an issue here when "stealth mode" is enabled in security preferences of the OS X operating system?
15-05-03 11:30:08 Firewall[74] krb5kdc is listening from 0.0.0.0:88 proto=6
15-05-03 11:32:45 Firewall[74] Deny LaunchCFMApp data in from 192.168.0.197:61701 to port 2222 proto=17
15-05-03 11:33:06 Firewall[74] LaunchCFMApp is listening from 0.0.0.0:3323 proto=6
15-05-03 11:34:18 kernel AirPort: Link Down on en1. Reason 4 (Disassociated due to inactivity).
15-05-03 11:34:18 Things[435] network reachability has changed: not reachable
15-05-03 11:34:18 configd[39] network configuration changed.
15-05-03 11:34:19 [0x0-0x23023].com.google.Chrome[277] [277:25347:0503/113419:ERROR:connection_factory_impl.cc(335)] Failed to connect to MCS endpoint with error -106
15-05-03 11:34:23 Firewall[74] krb5kdc is listening from :::88 proto=6
15-05-03 11:34:23 Firewall[74] krb5kdc is listening from 0.0.0.0:88 proto=6
15-05-03 11:34:28 kernel AirPort: Link Up on en1
15-05-03 11:34:29 kernel AirPort: RSN handshake complete on en1
15-05-03 11:34:31 Firewall[74] krb5kdc is listening from :::88 proto=6
15-05-03 11:34:31 Firewall[74] krb5kdc is listening from 0.0.0.0:88 proto=6
15-05-03 11:34:40 [0x0-0x23023].com.google.Chrome[277] [277:25347:0503/113440:ERROR:connection_factory_impl.cc(335)] Failed to connect to MCS endpoint with error -106
15-05-03 11:34:44 Things[435] network reachability has changed: reachable
15-05-03 11:34:44 configd[39] network configuration changed.
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:5262 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:63606 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:59695 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:61429 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:50196 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:64605 from 192.168.0.1:53
15-05-03 11:34:52 Firewall[74] krb5kdc is listening from :::88 proto=6
15-05-03 11:34:52 Firewall[74] krb5kdc is listening from 0.0.0.0:88 proto=6
