sunnyorlando's avatar
sunnyorlando
Repeater slows down every couple fo days - needs reboot
  • Hardware Version: WN2000RPTv3
  • Firmware Version: V1.0.1.26
    • I have not upgraded to V1.0.1.4 because as I usnderstand it its only a GUI change.
I've had this range extender for a bit over 1 year. While it works, its works fine. However, over the past 6 mos or so I've been batling a sluginesh that builds up over just a few days - 3~5. at that time it goes to a crawl - I could walk the bits over to the corresponding web site faster.
I've read a number of similar issues and possible solutions. I have applied some of these changes to it based on recommendations I've read: fixed IP within my network, firmware update. Thats really I all I know to do so far.
The only solution I have so far is to reboot it evey 2~3 days to get the right speed back.
Obviously this is not how this is supposed to work.
I'd probably be happy if lacking any real Netgear solution I could have it reboot automatically evey night...
That said - any additional recommendations?
  • Just in case I decided to update the firmware since in all likeliness someone will tell me to do that first even though it's proabbly unrelated. So that's done - and I don't see anything different.
    Now -
    When I did the 'upgrade check' the response was that my firmware was up to date.
    So I did a manual download and update.
    Once completed, I got the message that a new version was available - referring to the old version I just replaced. Basically a downgrade - go figure.
    See attached below.
    A New Firmware Version is Found. Do You Want to Update to the New Version Now?
    Firmware Version
    Current Version:V1.0.1.4
    New Version:V1.0.1.26
    Release Notes:[New Features and Enhancements] Updated Firmware for compliance to the new regulatory standard.
    [Bug Fix] Security Fixes.
    [Bug Fix] Fix WPA2 4-way handshake Vulnerability.
    Firmware Version
    Firmware Version
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi sunnyorlando,
      Please make sure you do a factory reset after the firmware update if you haven't done it yet. Please keep us posted if the issue persists.
      Dexter
      Community Team
      • sunnyorlando's avatar
        sunnyorlando
        Hi Dexter,
        Thanks... I've done that already - additionally as memtioned in the post I have to reboot regularly anyway to bring the speed back up.
        So since I rebooted the day before yesterday after the latest firmware update, I'm now waiting to see the next slowdown - usually 2~3 days in between.
        DexterJBwrote:
        Hi sunnyorlando,
        Dexter
        Community Team
