mrw538's avatar
mrw538
Follower
Mar 19, 2014
RF interference
I have a NetGear WRN3500 and it is dumping intermittent RF interference at: 155.865 and 159.345 plus several more. It is bad enough to set off the auto squelch on a HT1250 Motorola hand held at 15 to 20 feet through the walls. With the antenna off the radio it will break the squelch at 3 to 4 feet.
  • Retired_Member's avatar
    Retired_Member
    Try a re-set or different channel, try a different router, determine if router or client is causing it, take radio in for service or disable auto squelch and set it manually.
