MNicastro
Apr 27, 2023Aspirant
Set up NETGEAR WiFi range extender to use the same wireless network name (SSID) as my router
I have a Netgear EX6100v2 (AC750) Wi-Fi Range Extender. I have a lot of devices that are using the SSID as on my Frontier ARRIS NVG468MQ Gateway and I want to extend the Wi-Fi coverage using the Range Extender but use the same SSID so I don't have to reconfigure all my devices. How can I set up the range extender to use the same wireless network name (SSID) as my router without any network issues?
What firmware is on the extender?
The EX6100v2 is a mesh extender. so if setup using wps or using the default settings from the installation assistant, it'll seutp in mesh mode with the same ssid as the router.
- MNicastroAspirant
Great, thanks for the response. When setting up the extender in AP mode it created the SSID with an 'EXT' on the end of it. So I just renamed the SSID on my Extender the same as on my router and it seems to work fine so far.
