Fredbird82
Apr 16, 2017Aspirant
Setting up multiple AC1900 Nighthawk Wifi Range Extenders
I want to setup a second AC1900 Nighthawk Wifi Range Extender. I have one at the north side of my house and it works great. I want to add a second one to the south side of my house.
1. Will This work?
2. If it will, the current extender shows up as _2GEXT and _5GEXT. What will the second extender show up as?
- Yes.
- It might be the same, but you can always rename them.
- Fredbird82Aspirant
thank! How do I rename them?
Log into the extender at mywifiext.net. You need to be connected to the extender. Check the manual if you need help.
