alecasa087
Nov 18, 2015Follower
Slow connection
Hello everyone I have a modem connection Netgear DGND4000 Modem Router always 10 megs, today I configuarato Netgear WN2500RP I needed for the room for the second PC without wifi, but since he 'turned on and set the connection and' stable 7 megs, and 'a problem or I can solve it in some way?
1 Reply
- nhannNETGEAR Employee Retired
Hi alecasa087,
Using a WiFi extender on extender mode will halve your normal network speed.
You can try changing the WiFi channel on your Router to improve your performance.Or consider a NETGEAR Powerline if that fits your requirements.
