Anonymous's avatar
Anonymous
Feb 11, 2013
To All Those with WN3000RP Connection Problems
I see lots of posts here about people having problems with this unit.
You should be aware that earlier versions of firmware had lots of problems establishing and maintaining connections with the router.
The first thing you should do when you are having any problems with your WN3000RP is make sure you have the most recent firmware installed. *All* the problems I used to have with my connections were solved with the upgrade to the current firmware, which is version 1.0.1.34.
About a month ago I bought another of these, and it had older firmware installed on it, so don't assume you have the most recent version just because you just bought the device.
If you need to update your firmware, it is safest to do it over a WIRED connection. Consult your manual.
When posting about your problems, it is helpful for you to give the following information:
What firmware version is installed on your WN3000RP?
What is the make and model of the router are you trying to connect to?
What firmware version is on your router?
  • Anonymous's avatar
    Anonymous
    Melviba wrote:
    Thanks for the response PigVomit, however, I've checked the signal strength to death, generally the signal strength is between 50 and 30% so really shouldn't be an issues.
    I think their may be a conflicting signal on the channel. However, when I move WN3000RP to what looks like the strongest channel, it seem to automatically become the weak one. Confusing as hell.
    If it's only between 30 and 50 that's probably the problem. That's fairly low.
    Just move it closer and see how it does. Humor me.
    As for the channel, that could also be it, but I kind of doubt it. The extender channel defaults to the same channel(s) as the primary router. I recommend using Inssider (at Metageek) to check for the signal channels in your area. Use the clearest channel of 2, 6, or 11 (just trust me on this, or do research on your own as to why you don't want to use other channels).
    Anonymous
    I meant channels ONE six or eleven, not two.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello Jic
      Did you try moving it back to see if it connect again?
      DarrenM
    • DarrenM's avatar
      DarrenM
      I would try a factory reset again make sure you hold the reset button for 10+ seconds and then set up the extender again.
      DarrenM
  • I have Windows 8 and can't get anywhere with setting up my WN3000RP. I can't go START- ALL PROGRAMS because there is no such thing in Win8 that I can see. Does the smart wizard work with Win8?
    I also can't register it even though I am entering the right S/N so can't enter chat. I have tried calling umpteen times but all I get is a busy signal. I'm getting VERY frustrated. HELP!!
  • I keep having this issue
    The selected network is no longer available. Please make sure the existing network equipment is within the proximity of the Extender.
    If you have Access Control List (ACL) enabled in your router, please make sure you have added below MAC address into your router's Access Control List (ACL).
    The Extender MAC address is 20:E5:2A:15:58:BA
    Your wireless adapter MAC address is CA:BC:C8:CE:AC:7E
    suggestions? I have no clue what all this means
  • Had the same issues and proximity wasn't the cause. Read in another post to try changing from WPA2 to WPA. As soon as I did that, it connected. I haven't attempted switching back now that it's connected, but the WN3000RP's settings do include WPA2.
  • Extender stopped working after I moved it to another plug. Can hear hum when hit on button. Tried reset and on off.
  • It does come on. When I press on and put to ear I hear a hum and no lights and hum stops when I press off.
  • Has anyone had the issue with data increase with the extender I have a data plan of 350 and I had it running for over 2 years and never went over but recently about 4 monthes ago I had moved it and redid eveything and for the last 4 monthes my data has be going over our data plan by 100 to 150 GB per month. Has anyone had a issue with the extender running when it doesn't need to be?
