brucecjohnson's avatar
Nov 28, 2024
Uanable to Join network "NETGEAR_EXT" Network - Exrender not found
MAC OS SEQUOIA V15.11
Installed Network hardware - Netgear Orbi RBK852 Tri Mesh Router & Satellite
  • plemans's avatar
    Wow, your description left a lot to be desired.
    You posted about a _ext network but that you have an RBK852 which isn't an extender.
    Maybe a better description of what you have for your setup, what you're trying to do, and where it fails would help us to help you better.
      • plemans's avatar
        might mark it solved then so others aren't still trying to fix it
  • It is good you are troubleshooting the issue! Once resolved connecting to the "NETGEAR_EXT" network should be seamless and smooth.
