fflanders
Dec 19, 2018Aspirant
Unable to connect laptop to N300 EX2700, but can with other devices
I have successuflly setup my N300 EX2700 WiFi Range Extender and updated to Firmware V1.0.1.52 However:
I did so with an ethernet chord connected to the extender, in the same room as the rou...
Christian_R
Dec 20, 2018NETGEAR Employee Retired
Hi fflanders - Please refer to the article below. Once you're able to get into the extender's UI, please ensure that your Internet IP address is set to "Get Dynamically IP Address From Router" is enabled. In order to do this go to Setup>Internet Setup.
https://kb.netgear.com/29746/I-can-t-access-www-mywifiext-net-what-do-I-do
~Christian
fflanders
Dec 21, 2018Aspirant
Hi Christian,
What do you mean by, 'once you are able to get into the extender's UI.' By this, do you mean access the http://www.mywifiext.net/
page? How do I do the method: Setup>Internet Setup, to ensure that my Internet IP address is set to "Get Dynamically IP Address From Router" is enabled?
Is this done someplace within the windows OS control panel? Or elsewhere?
Thanks
