SquireDude66's avatar
SquireDude66
Unable to connect to MyWiFiExt.net w/eathernet connected
WN2000RPTv2
Sorry do not ahve access to the unit to give you firmware or other details...
I am trying to reset myWiFiExt and create a new connection to a new Access point.
I am unable to get to MyWiFiExt.net... it tells me I am not connected...
I have rest to factory... that resolved the issue and I was able to see a list of Access Points, I was able to set the password and it responded with the new name of teh connection but as soon as I connected to it everything went off-line again.
I power cycle the Extender and it does nothing for me... I am unable to connect to MyWiFiExt again.
Thi sunit is old and it has had its ups and downs for years.  It will lose its connection and I would have to power cycle it get the connection back.
Is this unit now completely useless and headed for the trash?
Or is there hope and a solution to my delimer?
Thanks in advance for you help.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi SquireDude66,
    Welcome to the community!
    You can try re-flashing the latest firmware then do a factory reset.
    Dexter
    Community Team
    • SquireDude66's avatar
      SquireDude66
      Hi,
      Thanks, I have tried a reset using the button on the rear ot the unit.  Not sure if it worked as I am unable to open MyWiFiExt.net...
      I think the unit has died...
      Is there any other test or ways of accessing the units Dashboard?
      Thanks
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi SquireDude66,
      I have sent you a message. Please check your inbox.
      Dexter
      Community Team
