kk4mds
Jul 07, 2016Aspirant
Unit not connecting
Unit worked for quite some time. Had to replace wireless router with same make and model. Tried to connect unit to network using WPA buttons. Would not connect. It connected to wireless computer,...
- Jul 11, 2016
Hello kk4mds
Since you got a new router I would suggest factory resetting the extender and doing the setup again some setting could be causing the issues.
DarrenM
DarrenM
Jul 11, 2016Sr. NETGEAR Moderator
Hello kk4mds
DarrenM
kk4mds
Jul 12, 2016Aspirant
My main problem was that I could not use the alternative method of using the webpage because I didn't remember what the user name and password was. That problem has been solved and the unit is working fine.
Thank you
