btberlin's avatar
btberlin
Follower
Dec 02, 2021
upgrading firmware on EX7000 Firmware Version: V1.0.1.90_1.0 gets stuck at DOWNLOADING AND UPDATING
rebooted extender EX7000 Firmware Version: V1.0.1.90_1.0  On management page selected update firmware.  Starts, but gets stuck at downloading and updating language tables.  Need help with firmware update.
  • FURRYe38's avatar
    What browser are you using? Try a different browser? MS Edge or Firefox?
    Netgear has set up a community forum specifically for the WiFi Extender products. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
    Thank you.
    • jdguestsr's avatar
      jdguestsr
      Has this been resolved? I am trying to update from V1.0.1.90_1.0.156 to 1.0.1.106_1.0.190. Online update hangs on downloading and updating language table, manual upload fails with "firmware upgrade failed. Please check your file" error. This is with both Firefox and Edge browsers, and I have downloaded the firmware file several times (always the same size).
      I am having issues with the router dropping connections, so I would like to get to the latest firmware to see if the issue is resolved.
      Thanks,
