Greta_esq
Aug 28, 2014Aspirant
Using ReadySHARE print feature w iPad
Is it possible to "airprint" from iPad & iPhone over the wifi? I've successfully set up ReadySHARE and printed from iMac, but iPad isn't recognizing printer (and is wifi connected thru EXT) Tha...
Greta_esq
Sep 04, 2014Aspirant
Minions08, I have repeated steps w Genie, and this same warning note continues to interfere w successful airprint :confused:
[QUOTE=Greta_esq;481551]
"NETGEAR router is not found or is not supported. Also make sure the device is not connected to the guest network of the router, and no IPv6 is enabled."
Thanks in advance.
Thanks in advance.
