Greta_esq
Aug 28, 2014Aspirant
Using ReadySHARE print feature w iPad
Is it possible to "airprint" from iPad & iPhone over the wifi? I've successfully set up ReadySHARE and printed from iMac, but iPad isn't recognizing printer (and is wifi connected thru EXT) Tha...
Frustrage
Oct 09, 2014Aspirant
Update: Aha, even though I remember updating the software, apparently not as recently as I had thought. Did so. Great same screen as the directions screen. However, not printing from iPad. Did verify printer was working from iMac. Used AirPrint setting to select the printer. Verified we were all singing on the same set of IP addresses. The router found the printer, the printer found the router. But still not printing. Refresed, reset, rechecked. But still no printing.
From the iPad I am able to select the printer. But, after clicking on Print-all is quiet on the printing front. Would a recent update to iOS 8.0.2 be a factor?
Closed down and restarted iPad. Am about to do the same with the iMac-but if the router sees the printer and the printer sees the router and the iPad sees the printer and the router sees the iPad?????
