Greta_esq
Aug 28, 2014Aspirant
Using ReadySHARE print feature w iPad
Is it possible to "airprint" from iPad & iPhone over the wifi? I've successfully set up ReadySHARE and printed from iMac, but iPad isn't recognizing printer (and is wifi connected thru EXT) Tha...
Fairytail
Jun 17, 2015Virtuoso
When printing on your iPads or iPhones via Airprint, make use that the computer where the Genie is running is turned on and make sure to update the iTunes and adobe reader.
