dberezin
Apr 18, 2012Aspirant
Using Same SSID as Router
Hi, I know the help within the MyWifiExt application says not to use the same SSID, but doesn't that defeat the purpose of the range extender? Is there an issue if I use the same SSID that the rou...
jkru
Dec 13, 2012Aspirant
jmizoguchi wrote: It's fine to use same SSID name main and _ext ssid
Just to clarify are you saying I can use the exact same SSID on both the Wireless Router and the Range Extender? Don't they have to be on a different channel at least?
