harvonkeuka
Sep 24, 2013Aspirant
WG602v4 No Internet With Time Warner Cable Modem
Like many other posts, was working, stopped working. Not knowing how someone else set it up way back when, I reset the WG602 to factory defaults.
Cable modem is fine. I plug in laptop via ethernet cable and I see the outside world. However, when I connect the WG602 and attempt to connect wirelessly, I am not able to get an IP. ipconfig /all reports:
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Dell Wireless 1395 WLAN Mini-Card
Physical Address. . . . . . . . . : 00-22-68-D2-7A-36
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IP Address. . . : 192.168.0.120
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
DNS Servers . . . . . . . . . . . : 209.18.47.61
I have gone through the usual machinations of powering down and restarting. Any ideas? Many thanks.
- jmizoguchiVirtuosowhat is the cable modem model
- harvonkeukaAspirantAmbit U10C018
- jmizoguchiVirtuosoAmbit U10C018 is basic cable modem with out no NAT so installing WG602 cable modem will not going work
You need a router behind it - harvonkeukaAspirantUh, . . . per original post it worked fine until recently.
- jmizoguchiVirtuosoStatic ip private ip PC using gateway ip of ISP and DNS also IP of ISP
Probably will not work
You need gateway cable modem and not just modem or wireless router - harvonkeukaAspirantMy friend's PC had an alternate configuration for her wireless adapter that looked like that. Maybe an IP changed. But I also connected at some point with my laptop and it is set to get IP and DNS automatically. What a mess. When I am there next time I am going to see if a Linksys I have works, but I agree the best solution is a wireless modem supplied by Time Warner. Thanks for your help.
- jmizoguchiVirtuosoJust install wireless router if you have spare
jmizoguchi wrote: Static ip private ip PC using gateway ip of ISP and DNS also IP of ISP
I am thinking about this some more, and I believe you are correct. Can you give me a bit more detail? I have little networking experience.
Sounds like:
Is that it? Thanks again. - jmizoguchiVirtuosoYou can try by setup static ip on wg602 with private ip , setup witelss etc
Connect to cable mode
You might able to get ip from ISP to sigle laptop
