JayKnaack
Dec 20, 2023Initiate
What I have. R6700v2, R6900v2, GS305E X2, what I want to do with what I have.
Just starting out. Funds are very limited. I have R6700v2, R6900v2, and two GS305E 5 port gigabyte switches. Will this work in the attached photo.I’m trying to cover the whole property with Wi-Fi and...
JayKnaack
Dec 22, 2023Initiate
That’s how I was going to set it up. The modem, main router in the house then the camper as an access point. Thank you, that helps a bunch. Now for the fun part setting it up. I’ll give an update when I got it setup.
Dec 22, 2023Guru - Experienced User
again, just make sure you have the router before the switch or you'll run into issues. Unless that modem has its own integrated router.
good luck!
