jmb3810's avatar
jmb3810
Which wi-fi extender works with AT&T
I need to get a wi-fi extender. Which is the best to get for an AT&T uverse aaris NVG589.
Thanks
  • StephenB's avatar
    Thanks
    This is an N300 router (single band, 802.11N).  A WN3000RP would work (and is the same speed as your router).
    Can you give us some more info on what you are thinking of doing -
    • If you are trying to cover a dead spot?
    • If you are wanting to provide ethernet for a device that has no wifi?
    • Something else?
    Either way, how far away is the spot you are trying to reach, and what obstacles are there between that spot and the router?
    • jmb3810's avatar
      jmb3810
      I installed a Kuna security light and it needs a wi-fi signal. The signal gets very weak when it reaches the front door from the back of the house.
      • StephenB's avatar
        Sounds like the WN3000RP would be reasonable then.  Place the extender towards the front of the house (close enough to the router to get a good connection to it, but also close enough to the Kuna to reach it).
