d_rick
Dec 13, 2013Tutor
Why is speed capped at 300mbps on 5ghz band?
does anyone know why wireless speed is capped at 300 mbps on extender when it can range up to 600/1300 on AP side? question is specific to 5ghz band and using fastlane in following config: FastLan...
Retired_Member
Dec 14, 2013Because the link between the extender and router is 300 would be my guess. In AP it uses a wired connection which is a bit faster.
