stormann59's avatar
stormann59
wi fi extender frontier model no. ex6100
I have two different netgear products that I am supposelby able to use if linked by ethernet cable. My router/modem is a nighthawk 7000 cv2 and my extender is my old frontier ex6100. Any help would be appreciated if this is true would save me from buying anoather netgear extender. Thanks, stormann59
  • plemans's avatar
    not sure why say "old frontier ex6100"? maybe it was connected to your frontier setup?
    If its a netgear EX6100, it should connect to the C7000v2 (if thats what you have?) fine.
    If you're hardwiring it into the c7000, it'll run in access point mode.
    I would recommend factory resetting the EX6100 before setting it up.
    https://www.netgear.com/support/product/EX6100.aspx
    • stormann59's avatar
      stormann59
      Thanks will try reset It originally was purchased through frontier when I was using them. When activated it still shows frontier which of course is no longer supported.
      • plemans's avatar
        I didn't know frontier sold their branded extenders.
        What firmware is on it? (firmware number)
