frustratedkev's avatar
Sep 22, 2018
wifi extender crashing out to captive.apple.com
I have just moved house and need to connect my POwerline WN3000RP Adapter to the new router to extend my wifi around the house.  When trying to set the thing up, I keep getting to the last step when I am presented with a blank login page headed Captive.Apple.Com.  I have no option to login, only cancel, and my setup fails as a result.  I have tried on 2 separate Macbooks and an Ipad, all get the same result.  I've tried performing multiple factory resets on the adapter, which resets it to Netgear_EXT and have tried every combination of security settings, including no security.  Nothing works.
I've found a couple of other entries on this forum but they don't have a resolution - just suggestions to try things I've already tried. .
Is this an Apple incompatibility thing?  I'm wondering whether to get some support from somebody with a Windows device.
Any ideas?
  • michaelkenward's avatar
    michaelkenward
    The WN3000RP is not a powerline device, despite its appearance. It is a wifi range extender. So this is not the best place to ask for help.
    Have you checked for messages in the appropriate section of this forum?
    WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
    You say you found nothing useful, but I see several "solved" threads.
    The message you see seems to be from Apple. Does it come up when you try to connect to the wifi?
    If you haven't found it already, there is support for this device at the end of this link:
    >>>WN3000RP | Universal WiFi Range Extender | NETGEAR Support<<<
    • StephenB's avatar
      The Macbook is thinking that your extender is a public wifi network that needs a web logon.
      You can yry "forgetting" the network in the MacBook and then rejoining it.  Another option is to install firefox or chrome, and use that for the setup.
      • frustratedkev's avatar
        frustratedkev
        I tried the suggestions included here but to no avail.  I realise now though that the problem was that I was trying to extend the netwrok from my main house to the extender using an Ethernet cable as teh wireless signal couldn't penetrate the walls.  The Extender is only designed to work wirelessly so didn't work.
        In case anybody else faces a similar problem, I connected a 2nd router in my cottage using an Ethernet cable, connected to the router in the main house.  I was then able to connect the extender wirelessly to the additional router and all is well.
