frustratedkev
Sep 22, 2018Aspirant
wifi extender crashing out to captive.apple.com
I have just moved house and need to connect my POwerline WN3000RP Adapter to the new router to extend my wifi around the house. When trying to set the thing up, I keep getting to the last step when ...
michaelkenward
Sep 30, 2018Guru - Experienced User
frustratedkev wrote:
The Extender is only designed to work wirelessly so didn't work.
Most extenders can work in AP mode. The manual says the WN3000RP can do this, but it isn't clear that it is using the term in the same way.
I connected a 2nd router in my cottage using an Ethernet cable, connected to the router in the main house.
If you really do have two routers on the network, then you have to be careful in how you set them up. With two routers on your network, you can end up with competing DHCP servers and local address conflicts. To avoid that you need to set the routers up with the right DHCP and IP address settings.
Unless you have specific reasons for using two separate routers, to create two separate networks for example, it is usually easier to use just one router and then to set up the second router as a wireless access point. Netgear advises this, as does just about every site you will visit.
frustratedkev
Sep 30, 2018Aspirant
Thanks for the using router as access point tip. Guess what I'll be doing this evening!
