smokwells's avatar
smokwells
Follower
Feb 09, 2018
wifi extender ex6100 hooked up as waypoint with cat 5e cable, cuts out
I have a Netgear ex6100 wifi extender set as a way point.  It is hooked up with a 50 foot cat 5e cable.  At the other end is a sagecom router from Optinum.  I will get great internet conection for several minutes, and then nothing, It will then get good agian, and then cut out. Any help would be apreciated. thanks
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi smokwells,
    1. What is the firmware version of the extender?
    2. Does the issue persist if it is setup closer to the router (between 5 to 10 feet) with a much shorter cable (for isolation)?
    3. Have you tried using a different Ethernet cable?
    4. Have you tried connecting it to a different Ethernet port on the router's end?
    5. It is possible that 50 feet is too great of a distance for a consistent connection.
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi smokwells,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
