Bronnybeee
Jan 08, 2018Follower
Wifi extender EX6150v2 connection problems Help!
Hi, We have used this extender successfully for several months. We recently upgraded to NBN so have a new wifi router. We have followed video and connected it to new router using Ethernet cable. T...
jvasanth1984
Feb 18, 2018Virtuoso
Hi Bronnybeee,
If you are using it as extender, you need to reconfigure it with your new gateway and you should not connect it wired to the new Gateway as extender will get the signal wireless from the new gateway. Whereas, if you are using it as an access point, login to it and check the wireless password under wireless settings.
