RobRamshackle
Sep 08, 2015Aspirant
WiFi extender Failure
I tried using a netgear wifi extender last year, but it was such a failure as the signal continually dropped out making it useless. Anyway, this year I am adding a wired extension to my network, ...
nhann
Sep 08, 2015NETGEAR Employee Retired
Hi RobRamshackle,
Which WiFi extender are you using? and which router is connected to it?
Please connect an ethernet cord from your switch to your WiFi extender and set it up as "Access Point" not "Extender".
RobRamshackle
Sep 09, 2015Aspirant
Thanks, I can see now that this extender (WN3000RP) shouldn't be connected by LAN and only works via WiFi as an extender, not an access point. I'm going to open another thread as my main problem is not this now. Thanks for your help anyway
