Timkathome's avatar
Jul 12, 2020
WiFi extender N300
I can't connect any of my devices through my N300 WiFi extender, model EX2700.
I followed the setup through wps which seems to have worked because the extender now shows on the list of available networks. When I then try to connect wirelessly through it the 'Device' green light illuminates for a few seconds before going back off and I just get the message 'Could not connect to WiFi network'. I've done a factory reset and tried three devices (phone, tablet and laptop) but nothing will connect to the extender.
Unfortunately I bought this 54 weeks ago but have only just tried to set it up so can't get any technical support and the warranty has now expired. 😡
Any simple suggestions really appreciated. I'm not at all technically minded!
  • plemans's avatar
    Jul 12, 2020
    If you click on the support link I gave you, the 2nd video on the support site shows you how to use the installation wizard.
    • Timkathome's avatar
      Timkathome
      Tutor
      What/where is the installation wizard? Sorry if that's a really dumb question, as I said, I'm not at all technically minded...
      • plemans's avatar
