SEANBEAN8
Oct 20, 2018Aspirant
Wifi extender no difference
Hi there
i recently bought a netgear wifi extender (NETGEAR 11AC 750 Mbps (300 Mbps + 450 Mbps) Dual Band Gigabit Wi-Fi Range Extender with External Antennas (Wi-Fi Booster) (EX3700-100UKS) Wh...
Oct 20, 2018Guru - Experienced User
What color is the router LED on the extender?
Can you try connecting to the 2.4 ghz network with a phone or tablet (in the same room as the PS4), and measure the speed from that device? Also, measure the speeds to the wifi box and the extender in the same room as the extender (using the same phone or tablet as the first test).
