GreenPeter's avatar
Feb 12, 2016
WiFi Extension to R7000
Hi -
I have recently installed a Nighthawk R7000, but it needs a range extension to get to some parts of the house. The R7000 is AC1900 rated. I'm thinking of buying the EX6150 range extender, which is rated up to AC1200. Is this still compatible with the R7000, albeit at a slower speed? I'm put off buying an AC1900 extender as the price is 2-3 times higher than an AC1200 unit.
many thanks for any advice.
Peter
  • Should work, and as you mentioned, slower - but 50% slower, because of the nature extender's, they are penalized to about 50% loss of throughput. I would suggest buyng a router that can run in Access Point mode, with direct etehrnet connection, back to your base router, or, look at connecting the router and AP with ethernet powerline products.
    • GreenPeter's avatar
      GreenPeter
      Tutor
      thnx for this, Netwrks. Have taken your suggestion re powerline products.
