David81's avatar
David81
Follower
Aug 18, 2015
WiFi Range Extender - WN3000RPv3 - Solid amber light from power on.
Hello
I've just purchased Netgear WN3000RPv3.
I began to follow the instructions and upon plugging it in the power light went amber and that's it.
Any ideas?
Thanks
1 Reply
  • Try to hard reset the extender by inserting a paper clip in the reset hole (back of the unit) and hold it until the extender status LED flashes amber.
