azzurra
Sep 30, 2018Aspirant
wifi range extender ex3700. the ROUTER link led flashes
the Router led is green....but it flashes.The Internet's connection is right...but I'd like to know why the led is flashing instead to be solid.Can you help me?thank you
azzurra
Oct 01, 2018Aspirant
I confirm that the model is ex 3700...
The led flashes only in green.....never other colors.
I update the firmware.
I access the extender using http://mywifiext.net/ (while connected to the extender)...the Internet connection is right...but for a meanwhile it is possibile to have a bad connection or no signal wifi....
for example..in this moment it is all right.
and the led is solid green.....
It is possibile to download an APP in Smart tv to control the interference of the signal?
Oct 01, 2018Guru - Experienced User
I don't think the flashing is caused by interference.
Apps can look at the signal strength of various wifi signals, which can sometimes be useful in choosing the channels. However, there aren't any apps like that for my own SMART tv.
