daneal2674
Sep 18, 2016Aspirant
WiFi range extender for WNDR3700v3
Would like to find the best Netgear range extender for my Netgear WNDR3700v3 wifi router. Any suggestions?
- DarrenMSr. NETGEAR Moderator
Hello daneal2674
This is up to your budget and what type of features you are looking for on a extender. Do you need any Ethernet ports or are you just looking for something simple to extend the wifi?
DarrenM
- daneal2674Aspirant
Something inexpensive and simple. I do not need any extra ethernet ports. Just need to extend my wifi range.
Hello daneal2674
If you have a 802.11 AC router I would suggest a Ex3700 if you have a 802.11 N router you may want to look at the Ex2700.
http://www.netgear.com/home/products/networking/wifi-range-extenders/?cid=wmt_netgear_organic
DarrenM
