Stee's avatar
Stee
Wifi range extender N300
Buongiorno,
Ho acquistato wifi range extender N300 per amplificare il segnale wifi in tutta la casa.
Peccato che il led client non si sia mai acceso e non consente il log alla rete nuova_EXT
Consigli?
  • plemans's avatar
    Factory reset the extender. Push and hold reset while its powered on for 7-15 seconds.
    Then re-run the installation and use the installation wizard and not using wps. Wps gets coded different between different manufacturer's and can create issues.
    • Stee's avatar
      Stee
      Done....but it doesn’t log the network
      • plemans's avatar
        this didn't help. it didn't explain what you did. "log the network" can be taken many different ways.
        Please be precise in what steps you did, where the errors are, and whats going on. I'm not there to see so I can't help without details
