mnio's avatar
mnio
Win 10 says EX7300/AC2200 WiFi Mesh Extender isn't secure
Hi
Occassionally Windows 10 will pop up the attached notification on my screen. I believe I followed the simple instructions and am unsure what I need to do to rectify. Any hints on what I need to look for or change in the set up of Windows or the Router software?
I did have performance issues when sharing the wifi names with the TP-Link router. I ended up having separate wifi names and the connection is pretty much rock solid. The warning was before and after that set up change.
Cheers
  • plemans's avatar
    what method of security did you set on your network?
    Wep, wpa, wpa2?
      • plemans's avatar
        On both the router and the extender?
        You can log into the extender and check its wireless security settings.
        any other device giving you the notice?
