DAVnCHAINS
Jul 30, 2013Aspirant
Wireless connectivity issues..please help?
Hey I'm new to the forum and not quite sure if I'm in the correct place. My wireless connection as of late has been spotty, getting a message primary dns server not responding. It seems I have fixed...
LindaPat
Jul 31, 2013Aspirant
I'm new here also and having a connectivity issue as well. I have a Netgear N600 model WNDR3400v2. I have no issues with this unit except the signal is not strong enough in my son's room 2 floors up.
I just bought a used Universal Dual Band WiFi Range Extender model: WN2500RP from my son's friend. He moved and is now directly connected. So I know this unit worked last month at his home.
I hit the reset key on the bottom of the unit and have a green power button. I placed the unit on the desk next to the router to help keep any other wireless interference to a minimum. I have my laptop with me in the room to facilitate the setup.
Using setup Option 1: I pushed the WPS button on the back of the unit and then pushed the big blue WPS button on the router. The router has both 2.4ghz & 5ghz lights lite up on front. The green WPS button flashes on the extender for a while then goes blank. I am unable to connect to the www.mywifiext.net page, it "does not exist
I looked through the forums for help and couldn't either find or understand the solutions. Any help you can give would be appreciated.
