Lancep17
Dec 27, 2013Aspirant
Wireless Extender WN2500RP
Hello everyone, I am having trouble with my extender keep connection. It can go for 10-15 minutes strong, but it then will disconnect randomly and then come back up. I have made sure that the firmw...
Lancep17
So i ended up factory resetting my extender, and it seems to be working better. I also moved my extender a bit farther away from my xbox which may have been causing interference with the extender. I can not change the channel on my Extender as it is says auto and wont let me update. http://imgur.com/DbP6IiB
Also my internet has greatly plummeted since moving the extender, i usually get 22 down 14 up i am now getting http://www.speedtest.net/my-result/3191685756
Internet 2.4GHz is currently amber. Getting ready to reset main router to see if that can help with internet speed
