jamesallen
Nov 06, 2015Follower
WN1000RP issue
Hi all,
I've followed the setup instructions for the WN1000RP wifi booster. It connects without any issue to the router via the WPS setup but when I try to access the _EXT network it repeatedly tells me that there is a password mismatch. Any ideas what's going on?
I can't conect to the Netgear smart genie steup as I can't connect to the _EXT network
Regards, James
- nhannNETGEAR Employee Retired
Hi Jamesallen,
Can you please reset the WN1000RP back to factory defaults?
Press and hold the Factory Settings button on the side panel for 7 seconds. The booster resets, and returns to its factory settings.
Then try completing the setup via your internet browser, see page 11 of 35:
http://www.downloads.netgear.com/files/GDC/WN1000RP/WN1000RP_UM_20Feb2013.pdf
- rakesh-netAspirantForgotten password ;Authentication error occurred
- rakesh-netAspirantmy netgear not open I forgot paasword
- DarrenMSr. NETGEAR Moderator
Hello rakesh-net
You would need to do a factory reset as nhann posted above after that you should be able to login to the extender with the default login of admin/password.
DarrenM
